I read 1fastkia's reply on how to replace the brake bulb, but I couldn't get the darn light assembly off. I unscrewed the 3 bolts inside the trunk holding the assembly, unscrewed a larger screwed in thingy, tugged and pulled and tugged and pulled . . . to no avail. The light cover (on the outside) wouldn't move more than 1/8 of an inch. I was afraid to try to pry the thing off because I would probably break it.
Help :(
1998 Kia Sephia
:grin: Hello BunnyShorts,
I have a 1998 Kia Sephia if it's anything like mine when you remove the screws there are on the right side of the light assembly two bolts that slide in and out to remove the light fixture try sliding it to the right a little and pulling slightly on the assembly and see if it comes off. :thumbsup:
