2000 Kia Sephia
My brakes are still working but when I step on the pedal it goes down. Not to the floor but I don't feel safe in a emergency stop. Also, have been putting fluid in the tank.wayyy more than I should have to. My first thought is a leak but where? I don't see any drippage from underneath the car. Any help would be appreciated. Thanks
Check the proportioning valve... Follow the brake lines from the master cylinder...it should take you to this valve.... I believe it is on the fire wall...
Another place to check is the rear brakes... You he Sephia has front discs and rear drums...
I wish that JesZek was still around as he was the specialist on Sephias...
... I wish that JesZek was still around as he was the specialist on Sephias...
I'm still here, somehow. (without motivation, only.)
Regarding the vanishing brake fluid, I kindly suggest to the one who asked, that he / she must check carefully the rear of each wheel, in order to locate probable leakages, either from the flexible rubber hose or from the pistons on the drums / calipers.
If there's nothing, then the fluid might be going inside the brake's Booster, which might lead to a sudden fail of the braking system; if you don't know what you're doing, please take your Sephia to a certified mechanic and let they fix it for you.
Other point to consider: Sephias with rear drums, have a design flaw that leads to make the rear drums to be poorly braking, due to misadjustment on the self adjusters known as "Struts" inside the Drums; either that or very wear out brake shoes, could make the pistons inside the drum brakes, to Deploy beyond they should, leading to an inner brake fluid leakage...
I suggest to start by inspecting the state of the rear drums, and the Proportioning valves; because the original ones are prone to Leak; Kia offers improved ones that are a direct replacement, cheap.
Kind Regards.
