1 - 1 of 1 Posts
1999 Kia Sephia
Hey, quick question hope someone can answer. I have a 1999 Kia Sephia and the negative battery terminal was so loose you could lift it off with your fingers, no tools needed. We tried to replace it and ran into two problems. One problem is that the stores here sell a universal connector but the cables will not fit into it. Second issue is the cables are originally soldered together with a black piece at the end I guess holding the wires together. Do you just cut them and make two seperate wires then stack them and twist them together and put them into the new terminal connector and tighten down the bolts? Second is with the universal connectors does anyone know the size of the nut (we lost one and the ones to replace do not fit) because the idiots in my local stores would rather sell some car wash than sell a part to a customer.
Thank you for your help.
1 - 1 of 1 Posts
