I have an AT 2001 Kia Sephia LS...My idle is sometimes fine and sometimes rough and very very low...so low that the car will die. I got the codes checked at Autozone and the IAC valve came up numerous times. Kinda spendy $130 part so I dont want to buy it unless I know for sure. Does this sound like the likely cause? Where is this located on my car and is it an easy fix? All help is greatly appreciated.. thanks
99 Kia Elan 1.8L, 17 Ford Edge Sport 2.7L V6, 15 Mustang 3.7L V6, 2013 BMW K1600 GTL
The IAC could lead to incorrect idle speed, and most often can be sorted by cleaning with carb cleaner. It's mounted on the throttle body.
Take a look at the KiaTech wen site and you'll see pictures of the mounting location.
If it's misfiring, then it's more likely bad spark plugs, HT wires or coils.
