1 - 20 of 197 Posts
2014 Kia Sorento SX AWD, 2013 Ford Escape SEL AWD
Wondering if anyone else has experienced this. I have a 2014 Sorento SX AWD ~18,000 miles. At a dead stop, if I turn the wheel approx. 1 full turn left or right and accelerate I get the feeling of going over a rumble strip as if the awd might be slipping or the rear is slipping. Occasionally I can duplicate the issue if I am going 10-15 mph and turning. Has anyone else experienced this and or know what this may be ? I don't recall it ever doing this before. I did take it to my Kia dealership and took a mechanic out to duplicate the issue, however he told me he would need to contact Kia to find out what to do..? Any help / thoughts are appreciated.
I have been noticing the same thing, recently. To me, it feels similar to a vehicle with a locked rear diff that is binding around corners. I was wondering if maybe the center diff is sometimes engaging on its own, without hitting the button or causing the light on the dash to come on. I have yet to contact my dealer about it.
Discussion Starter #3 (Edited)
Its almost like an old 4 wheel drive truck and you'd get out, lock the hubs (ha, like having to get up to change the channel on the tv, before remotes) and make a tight turn. Not quite as dramatic as that, but a similar feel. Almost like going over a short light duty rumble strip. I'm waiting to hear back from the dealer. I'll keep you posted if/when I hear anything.
I'm guessing you didn't have the AWD locked in, Right?
Either way, AWD is always engaged at least 90/10 % on all these Kia, & Hyundai AWD vehicles.
If that means anything to you?
2014 Sportage SX AWD
probably a combination of the ESC and AWD. the ESC brakes the wheel that is spinning/lost traction, and the AWD sends power to the rear wheels.
from the 2014 Sportage manual
Tight corner brake effect
Tight corner brake effect is a unique characteristic of four-wheel drive vehicles caused by the difference in tire rotation at the four wheels and the zero-degree alignment of the front wheels and suspension.
Sharp turns at low speeds should be carried out with caution.
The Electronic Stability control (ESC) system is designed to stabilize the vehicle during cornering maneuvers. ESC checks where you are steering and where the vehicle is actually going. ESC applies the brakes on individual wheels and intervenes with the engine management system to stabilize the vehicle.
http://www.kia-forums.com/general-kia-non-model-specific-discussion/199097-dynamax-awd-system-explained.html
the Dynamax AWD system is always on, but for fuel economy it will try to go 100% front wheels as much as possible.
The computer algorithm for the clutch looks for consistently good front-end traction and when possible will maintain 100% to the front wheels for fuel economy. The algorithm, however, is adaptive; in "sporty driving" it will apportion torque as needed between front and rear, Sackl said, and it will transfer 100% to the rear if appropriate.
Former 2013 Rio SX Owner, 2014 Sorento EX
We had the exact same symptoms with our 2014 EX. Dealer said the rear differential coupling was bad and had to be replaced. I don't know much about AWD parts but I knew based on the the way it was happening (turning from a stop and accelerating) I knew it had something to do with AWD. They replaced it and it is fixed....for now. Based on this thread though, I wonder how long until it "goes" again.
2014 Sorento SXL
Mines in the shop right now for this as I have been feeling this same issue for a long time. I have the 2014 SXL AWD. Since there is no code it requires the dealer to get approval from KIA to do anything before then can proceed. When I pull the 4WD fuse the problem goes away. Try that and see if notice the issue goes away.
2014 Sorento SXL AWD 3rd Row Titanium Silver/Black
Haven't been on the forum since I got my 2014 SXL after having a 2011 SX. I have this problem exactly as described. Dealer replace upper and lower steering stuff as directed by the Kia Tech Line guys at the factory because the dealer techs had no clue what was wrong. Of course this did not fix it. That was 2 months ago. I decided to let it go for a while hoping it would get worse and it has. Without question this is the AWD system. This is my 9th AWD SUV and it is definitely like everyone has described. Turn right or left and it is like an old time 4X system in low range. I want to take it for repair after someone on the forum has theirs repaired successfully. I can then take the results and prove to my dealer what the fix is.
Please, anyone who gets theirs fixed, immediately let us know so we can get widespread problem into the Kia system for all dealers to be aware of. THANKS, Bill
2014 Sorento SXL
Did you have a chance to unplug the 4WD fuse and see if the problem exists any longer? Try unplugging and start back up and try. I did this and the problem is gone. The dealer is replacing the rear coupler because of this and should be complete this week.
So you removed the fuse; road tested; replaced the fuse and the problem was gone? OR, did you remove the fuse to confirm to the tech the coupler was the problem? Thanks for your reply, Bill.
2016 Sorento SX Turbo AWD (sold)
My brother had the same issue with his 2015 SX. They replaced the AWD coupling and it's all good.
2017 Sorrento SX
My 2015 was doing the same thing from a dead stop turning left or right i would get a thumping sound and the car would jerk. First dealer was out to lunch and replaced the brake pads?
Second dealer diagnosed the awd coupler on the rear diff and this has fixed the problem.
Hope this helps.
Found the fuse, removed it and problem gone. Will take your work order to the dealer. Sincerely appreciate it. Will update after meeting with the dealer. Bill
Update: I emailed my dealer the link to this post and he ordered the part and I am scheduled for install Monday. Great use of this forum. I sincerely appreciate the attention given to the problem. Hopefully it will help other Sorrento owners.
A further comment about the forum, I have a Chevy SSR and participate in the SSRFanatic.com forum also owned by this company. SSR owner participation is likely the highest among any vehicle-brand. The information shared is far beyond any manufacturer info available especially since production ended 3-17-06. Our participation on this forum is just as valuable as this AWD problem has confirmed. My guess is Kia will put out a TSB on the problem and if so it will be largely due to the sharing of information on this site. A big thanks to all! Will update after my repair to confirm it did the trick. Bill
2014 Sorento SXL
My 14 SLX sat for a week at the dealer and yesterday the part was recieved and installed. The Replacement coupler did fix the thumping problem along with the bump from the rear end I would get when pulling the the driveway. Very happy now!! :) I will say after driving a 15 LX for a week with the shorter wheels and larger tire make a lot more enjoyable ride over the SLX wheels and Tires!!
2014 Sorento SXL
when you pulled the fuse cover look underneith as it lays out all the fuses locations. It will show as 4WD. After you start your vehicle back up you will most likely notice the problem is completely gone.
1 - 20 of 197 Posts
