hello everybody,
Hello to all
Owned a car Kia Cerato model of the 2007 with a problem in automatic transmission ....
When Iam driving a simple vibration occurs with an increase in the speed of rpm and the gear stuck in 3d and not responding.. And I know that through the transfer the gear to the manual ... This problem go after i stop the vehicle restarting the engine.
i tried these solutions:
1. changing the oil fluid.
2. changing the filter.
what else?
please help ....
2005 Blue Kia Spectra5 and a 96 Turbo Honda civic and a 99 subaru outback with a 2.5 rs turbo motor
I kind of have the same problem. but mine would not change to over drive (final drive) found out the that my tourqe converter was bad. I ended up replacing the whole trans and converter. only cost me 530 bucks and was fairly easy to install.
also i remember reading something on here about the same problem and the cause was a bad solder on the vavle body. i will looks for the post and re-post it for you.
