2004 V6 automatic.
a little history. car was wrecked rear view mirror wiring was pulled apart blowing fuse had tranny in failsafe. I fixed that problem. now when I put the car in Drive it pulls about 2 sec. then lets go (like i put it in N) however If i kick shifter over into Manul mode everything works as it should I can even put it back into drive and it all works good untill I stop. then I have to get it going again in Manual mode? any suggestions
2002 optima 2.4
Guessing here, but it sounds like the torque convertor disengagement isn't functioning properly... Assuming it has one.
the fuse that was blown went to the Home link system all that is seems good. I am not getting any codes. and I have checked the solenoids in the tranny with a ohm meter. I do not like to ask for help but I need some on this...
the Fuse was ETACS fuse that had the tranny in fail safe mode.
