1 - 9 of 9 Posts
kia sedona
hi im new ive just got a 2001 kia sedona 2.5 kia sedona it goes in first gear but then it wont change gear till it gets to 4,000 revs then it will go into second then 4,000 revs it will go into third hope you can help thanks
2001 Sedona 2.9 SX TD-still going/Toyota Corolla-DEAD/Citroen Xsara-DEAD/Ducati/Suzuki Bergman
Is your HOLD or POWER light on? if it is turn it off and be gentle with the throttle backing off at around mid range and she should change up..
Next, when was the fluid changed? it should be changed around 40k miles.
Finally, look towards the speed sensor or solenoids.
kia sedona
no light on fluid just been changed do you know were they are ive just changed the tcu because got told it was that then they sid it might be the ecu ijust dont know thanks
kia sedona
the car was taken to stoneacre and the put it on there machine found 2 fault codesp1631 canbus time out ec p0100 maf circuit malfunction. possible causes wiring,tcm,gearbox valve body they sid they could tell me wot it was so havnt got a clue just hope some 1 can help me thanks for the reply MichaelS
Hi, best bet is to get one of the manuals off of bruno1926, it will give you step by step guide to test the control system of the gearbox. It also shows where the bits are.
Banned
quote=darron48;421951]the car was taken to stoneacre and the put it on there machine found 2 fault codesp1631 canbus time out ec p0100 maf circuit malfunction. possible causes wiring,tcm,gearbox valve body they sid they could tell me wot it was so havnt got a clue just hope some 1 can help me thanks for the reply MichaelS[/quote]
Have a look at this , if I've got time in the next few days I'll have a look for the hard copy of the manual and scan a clearer one
kia sedona
Discussion Starter · #8 ·
thank you this site is good wish i used this before wasting money on stoneacre for them to tell me nothing thanks again all daz
kia sedona
Discussion Starter · #9 ·
automatic gearbox
it is the sensor but im a bit confused its got a mitsubishi logo on the side of it can anyone help thanks :)
1 - 9 of 9 Posts
