need an advice, i ama a newbie user of Kia CArens ,, the problem with the automatic transmission, while in D, with a speed of 30-40 km / h and above 60 km / h, the engine rpm indicator and audible tightened up to 3500-4000rpm, feels tansmisi displacement of 2 to 3 and 3 to 4 very problematic, whether it should be replaced 1 set? or get it serviced? anyone know where I can get automatic gearbox transmission with low price? or workshops to the recommendations in the area of ​​Bandung / west java?on.
try to reset on ECU, its fixed..buts still has no change while im driving..
is there any tips?
Cerato S Hatch Auto
Hard to work out your problem from the description. From the Speed & RPM, seems that transmission is staying in 2nd gear when you are expecting 3rd or 4th. Have you thought about flushing transmission and replacing fluid?
yes..
thats what i mean :D
flushing transmission and replacing fluid already done.. but still same problem...
