I am using a 2000cc CRDi 2006 sportage. when i exceed 110kmph the engine get cutoff automatically. after switching off and starting back to normal. the check engine light was ON and after some time goes OFF.
2012 Sorento EX AWD CRDI; 2007 Sportage EX CRDi 4WD; 1967 Mercedes 250S; 1958 DKW 3=6
Sounds like problem with a sensor probably the throttle position sensor or MAF sensor. I think you should run the diagnostics and check the error codes it throws out.
Please fill out your vehicle and location details in your profile so that we would be able to help you better.
