I just figured out today that when I have auto temperature control activated that the A/C will be activated, but the light on the A/C switch will not be illuminated (nor will it show on the little display).
I know that it is on because the air coming from the vents is very cold, even when it is hot outside. Also, if i manually activate the A/C, the temperature remains equally as cold coming from the vents and the light illuminates.
The only way I can get the A/C light to illuminate when on auto temp control is to turn the temperature all the way down to "low".
This makes me thing that my A/C is always on (so long as auto temp control is enabled, which it usually is), and maybe a reason for poor fuel mileage, as using the A/C increases fuel consumption.
I am also wondering if this has anything to do with the strange gurgling noise that I hear when the climate control system is on at any fan speed. Perhaps my A/C unit is stuck on and won't turn off? I was told that the advanced system on this car circulates refrigerant all the time (creating the gurgle) to keep the seals supple, but something tells me that isn't accurate... if that were the case would it not require that the compressor be running all the time, and would that not by design be somewhat inefficient?
Can anyone else reproduce this strange effect on their auto climate control?
I have a service appointment on friday to replace a broken seat belt clasp (broken upon delivery), and will ask them to look into the strange A/C behavior that is occurring.
