Titanium 2013 Soul 4U 2.4 Litre Coupe Mantronic Transmission Back Up Camera & UVO
Is there supposed to be an audible warning from the Back Up Camera as you get close to an object (except of course a "Crunch"), on the 2013 Soul 4U?
Thank you!!
Soul Plus 2012
Hi,Over the past 10 years I have purchased the 4 sensor reversing system with alarm and bar graph from China cost including freight is about AUS $25.00 and yes after fitting 5 sets to my different cars never had a faulty unit. I have installed both camera and sensor system to the +, the cameras nifty but the rear sensor far better as they allow you to concentrate on SIDE MIRRORS. WARNING fitting rear sensor kits is quite simple, but you must be so careful when drilling the holes to take the sensors,to low and the system will read the road way, remember if the car is fully loaded it will sit closer to the ground, mounted to high and you can miss low lying objects.
Regards Peter
