1 - 12 of 12 Posts
2011 Sportage EX 1.7cc Diesel - Manual transmission
ok i know i may be asking multiple questions. lol
recently i was on the continent driving faster than our normal driving on the island here, (our max speed limit is 80km/hr) lol
On going above 120km/hr noise from the sunroof started to increase, and going above 160km/hr and for a long period the sound will be annoying.
To all those sportage owners who has the sunroof option, is this a common issue? i asked the local dealer about it and they found nothing uncommon. during this trip i encountered some heavy rain also and if there was leak i would have noticed some water going in but there was none.
Any comments?
thanks
Sunroof open is going to make noise, but closed it's not bad. I have a roof rack with bicycle trays and that makes some noise but even then isn't bad with the sunroof closed. Can't hear it at all when the shade is also closed.
600RWHP HSV MALOO /SPORTARGE platinum TD
ROOF OPEN very noisey at above 60 k
CLOSED NO NOISE at 180 k
i am refering to driving with suroof closed. it is a bit noisy. dont know if it was due to cross winds as on other occasions with cover closed also i did not notice it.
kia
Discussion Starter · #6 · (Edited)
Some had a noise problem.:mad:
Look here there are some good pics.
The sunroof can be adjusted. (Torx bolts 2 on each side):eek:
You can do it yourself.:eek:
2 left hands?
Go to your dealer and let them fix it, show the pics.
lol thanks for the pictures bowie
Hehehe if only..........I could read dutch!!
lol
kia
lol thanks bowie
Hehehe if only..........I could read dutch or at least see the pictures!!
lol
????Google translate.
????Pictures should be visibel.
Settings on your computer/browser?
With thanks to Elmerblues from Kiaclub Nederland
Remove the front protection cap from the roofrail start pulling at the front, carfull its plastic.
If you got smaller tools you can leave them on
The two metal fastners should come out but they often don't
The inside of the cap
Open your roof and close it till here.
kia
Close up pic
Use this bit
TIP: Mark the position of the Bolts before you start
TIP: Adjust one side then the other side.
These tools are big if you have smaller you dan't have to remove the cover but like so you see more.
kia
The bolts are lose and now you can adjust
Adjusted in the most down position
Adjusted in the most up position (only to have a i impression)
kia
Check the adjustment of the sunroof it should be lower then the rest.
Discussion Starter · #11 ·
Thanks Bowie.
Nice of you to translate for us.
thanks agiain
2011 Kia Sportage AWD 2.0L
Mine has that noise also, like air is passing into it at 100km+ but its no biggie...
1 - 12 of 12 Posts
