Status
Not open for further replies.
Ill be installing a new amplifier and 2 12" subs, and I need to run a 4 guage power cable to my battery. Id rather not punch a hole in my firewall if I dont have to, so Id like to know if anyone knows where the factory wiring goes through the firewall.
Anyone know where that hole is before I start drilling?
Im not to sure about where it is on a rio but maybe same location as sephia. its almost dead center on the firewall!
Its under the brake booster (the big black circle under your hood LOL). The easiest thing to do is get a good flashlight, crawl under your dash on the drivers side and find a black "oblong'ed" shaped rubber gromet and pull it out. There are no wires that run through it. What I did was punch a hole in it slightly smaller than my wire and poke the wire through the hole then put the gromet back. It should make a tight seal if done that way. Good luck!
Matt
Status
