Hello
Anyone have the same problem as i do?
When driving, it is very cold, but when idle, it is not so cold.
Engine temp was good. My aircon have a pinhole leak, which i add refrigerant once a in awhile.
car is 182000 km. Sephia 1999
Thanks
2002 Kia Magentis
I think you answered your own question. You have a pinhole leak. The system is under pressure and will continue to leak until it reaches a certain level. The compressor will supply a cooler temp at higher rpms because of this. If your not going to repair the leak, I would suggest disconnecting the compressor as it will only lead to other problems.
In Canada, refrigerant is hard to come by unless you are in the field. Due to the greenhouse gas thing, a certified mechanic cannot "top up" a leaking system, It must be fixed.
