Posted in the 2010 and lower forum by accident then posted here in the right forum but mod deleted the one here instead of the correct one.
Ok I know this has been talked about a bunch in the towing threads. Well our 2017 has had a sagging rear since new. Even with groceries in the back the rear sags quite a bit. I can't imagine if you actually put 7 people in it as the rear bumper would be dragging the ground...
Well now with 30K on it and I have to make a 2K mile round trip with the trailer hauling the daughters stuff out to her from her storage place here. I was not looking forward to that long of a trip with the nose up in the air and no traction on the front wheels...
So I have finally installed airlift airbags in it. I have used them on many other vehicles and I will say that this one was the cleanest install I have ever done. The rear suspension lends itself to running the airlines nice and cleanly. The line can be run in the crossmember and just use grommets in the holes to protect the hoses from chafing. No holes to drill just a slit in the lower spring isolator.
I used the Airlift 60901 which others have installed in their 2017s as well. They fit but a slightly shorter bag would be preferred as this one is a little longer than I would have liked.
So far everyday driving is greatly improved. The rear is a little more planted and they don't know how to pave roads in tx so every intersection and driveway has massive dips and I nearly get sea sick. After the bags the rear doesn't bounce around like it did before and the overall ride is better.
I will take pics at a later date and will do a video when I get a chance of how I did the install and get it on my youtube page. But if you have any questions just ask.
