This is the third time that the Air Bag Warning Light has come on & stayed on. It first happened in April, then June and the latest time on August 25th.
Both previous times, the dealer confirmed the problem, scanned for codes, received code 'B1763-OCS ECU DEFECT' & then erased the code.
At the April service, they found the 'harness under the seat to appear disrupted' & they 'adjusted to normal'.
At the June service, the connection was okay. They indicated if it re-occurs they recommend the replacement of the OCS ECU.
I have not called the dealer yet as I was hoping to get some input from others if they have also run into this problem.
Any input would be appreciated.
Thanks GwK
Thanks GwK
