AirLift-off
OK, the Air Lift kit is installed, and it seems great. I have only towed once with it, but there is a noticeable difference in sag and ride with them installed and inflated to 35psi. The installation process was simple and straightforward, and yet somehow took me all afternoon lying on my back under the vehicle anyways. That might just me me though
Getting the bags inside the springs is tight, but do-able without dismantling the suspension. I just jacked up the car one side at a time and pushed them through the gaps in the springs.
Running the tubing in a clean fashion took some time, finding a path that avoids the exhaust heat, and leaving enough slack for suspension arm movement, etc.
When complete, I tested and thought I had a leak because each time I checked the pressure, it was 1-2 psi less than the prior check. After wasting time dismantling my work, I learned that the actual CHECKING of the pressure was releasing a bit of air as the gauge went on and off the valve. I guess because the bags have such small capacity, that makes a noticeable difference in pressure. Turns out, it was all good the whole time.
My next project was to install my new Andersen no-sway hitch, which I completed last night. It looks great and seems to work well. I will know more after a trip to the Whiteshell this weekend.
I will post some pics on return
