1 - 11 of 11 Posts
· Registered
checked out eibach springs' website. they have nothing for a carnival/sedona. looked at the link, too, but they sell only original kia accessories. frustrating that given the numerous aftermarket shocks out there, it seems none are available for a kia carnival/sedona.
· Registered
found out that kayaba actually has aftermarket shocks for a carnival. however, car parts dealers here only offer the model for the RS (w/o) ABS), i.e. 335024/25 while the kayaba website specifies a different part no. (335042/43) for the LS (w/ ABS).
can anyone refer me to the kayaba distributor in manila? can't find any listed in the website or the phone directory. if not, would you advise using the available RS model for my carnival LS?
thanks very much in advance, guys.
· Registered
When I got my carnival in 2002, I immediately changed the shock absorbers to Old Man Emu brand. Bought and installed at RATS along katipunan before the newly finished C5 underpass if you're coming from ateneo. It's not cheap but it's not that expensive either. Not sure if improvement in handling will be that noticeable. But the yellow shocks look great. Best to visit and ask for advice. By now they may also have springs available for Carnivals.
· Registered
You may also want to check and replace worn out suspension bushings including control arm bushings, body mount bushings, spring bushings, etc. Too bad high-quality polyurethane bushings aren't available in the Philippines. We'll have to settle for the mediocre black ones at the casa.
· Registered
Discussion Starter · #8 ·
interesting about the old man emus. i installed them in my sport trac last year, i think also from RATS but in pasong tamo. they said they didn't have a model for a kia carnival. website says the same. hence, the kayaba's, which has a kia carnival model per their website.
you're right about the bushings, of course. had them changed already, but the shocks really need to go. hopefully the supplier can source the right model.
· Registered
Maybe it's not specifically stated in their list that there is Old Man Emu for Carnival. But that doesn't mean there really isn't any. Here's a pic of mine installed around 4 yrs ago. It's still functioning great. Sorry, labo ng pic. I really should upgrade my cell.
· Registered
Discussion Starter · #10 ·
can i trouble you with the part no. of your shocks? like i said, i also went to RATS (in pasong tamo, but the same owners as katipunan) and they told me they didn't have a model for a carnival. i'd like to try again. many thanks.
· Registered
2002 Kia Rio5
Kia suspension parts list
shocks/struts-most likely KYB GR2's should be available for your car
Springs. Eibach are too soft, so are Intrax. Try H&R from california or B+G from Germany for good ones.
Sway bars and suspension components-Whiteline Racing in Australia. www.whiteline.com.au
try a US website at www.kfxperformance.com, they have a lot of Kia parts. Maybe they can direct you where to find what you want closer to home. The owners name is Bill Hurlin. he's a nice guy and very helpful.
air filters-K&N
spark plugs-best bet NGK iridiums. Denso are OK, but don't waste money on Bosch or Champion, they are basura.
Don't forget. a big problem with all Kia's. body flex due to unit body construction and thin sheet metal. Front strut bars can be adapted with brackets and spacers to bolt right into grab handles over the front and rear doors and they work and look great. If you can get one in Philippines. Get a floor bar brace, they make a huge difference getting power to the ground and stiffening chassis for better handling.
Anyone who wants instructions on how to adapt strut bars for use as roof braces. email me at
[email protected]
and I will send instructions and pics
Thats all I can think of for now.
Good luck
bm
1 - 11 of 11 Posts
