Kia Borrego & Sorento
Has anyone found an electrical connection inside the engine compartment to connect LED daytime running lights that would be activated on-off by the ignition switch?
i did that in mine (sorento).. you just have to get a relay harness or drl controller take a pic of your fuse box.. i wanna see if its similar to the sorento..
this is the trigger wire in the acc mode (1 click more and you crank the engine)
i have philips led daylightguide in my sorento
turns off after 10 sec you turned off the engine, starts right away when you crank it.. and it can be dimmed (dimming wire attached to park lights)
s1 by kenn_ex82, on Flickr
IMG_5423 by kenn_ex82, on Flickr
