21 - 28 of 28 Posts
2013 Kia Rio manual 6 speed (AU GDI MODEL) in black.
Discussion Starter #21
That would be awesome as I'm sure the picanto won't be too much smaller but within those measurements..
Comparing the pinout to the zero wiring harness might not be necessary from the ecu as I may end up going directly from the pedal to the motor controller being the ecu? Might not be necessary unless I need to use it for speedometer and that would be from a Kia Niro as that has the ability to monitor battery range, modes, statistics etc. and I'm looking for a manual for the Niro so I can see if there is a module wired behind the cluster to get data or any info from sensors on the car also..
So yeah this is going to be a little bit of an advanced project I think..
Those photos have been a massive help so far.
Discussion Starter #23 (Edited)
Discussion Starter #24 (Edited)
Seems to be a simple 6 pin connector for the Niro EV also.
Just need to find out pinouts and wiring for the niro and then compare to picanto and the bike controller and see what is necessary and what is not then wiring between the two systems will be easy as pie.
The zero wiring diagram has 7 pins so I can work out what pin goes where and if they're necessary and even if the ecu can be bypassed and wired directly to said components on motorbike controller.
If you wanted to take a look.. you're more than welcome.
Discussion Starter #25
The next thing I need to work out is paddle shifters for regen and mode switch..
Slow medium and hard and off for regen
Economy, performance and sports for motor "performance"
Discussion Starter #28
That's ok.. just post when you can..
Slowly getting my bank up to get a car in a few years.
Have a few other things first in mind and plenty of time too.
21 - 28 of 28 Posts
