Hi I have a 2013 Kia Sportage AWD 2.0L Turbo Diesel Auto. When driving the the accelerator pedal dies.
I can be driving a long and when I press the accelerator nothing happens - no revs the car just idles - as if I never pressed it. This has been getting worse over the last 18 months. In the beginning the car would go into limp mode and I could still drive it a bit but now the car just comes to a stop.
I have taken it to Kia and they reset the computer and could not get it to fault. About a week later it happened again and took it back. They replaced the EGR and it still did the same problem. They ended up replacing the accelerator pedal. This worked well for 5 weeks and then the problem came back intermittently. They said don't bring it back unless it happens all the time. Looks like the new accelerator masked the problem for a little while. So kept it for another couple weeks and after a bit of rain it came back worse than ever. No lights on dash but car does not go into limp mode. I just have to quickly pull over while I still have momentum.
Could it be the ECU or the actual wire/cable that connects the accelerator to the ECU needs replacing? Could corrosion on the connectors to the ECU cause this issue?
Any help would be greatly appreciated.
