1 - 10 of 10 Posts
Hello!
my ac has got a problem it injects just the hot air though I put it on Lo or if I turn it off!
someone who has the same problem?
Ceed 1.6crdi ('07)
Hello!
It is difficult to understand what you are setting.
What panel is it? You mention LO so presumably auto climate control?
What is the model and age of the car?
What is the outside temperature indication on the dashboard when you try this?
What are you turning off? The AC light should be on for AC function.
The car's inside temperature do I turn lo or any degree but will only warm air disgusting no matter what the outside temperature is out.
Car Kia Ceed
Year 08
Refrigerant in the system
Ceed 1.6crdi ('07)
Cerato S Hatch Auto
Sounds like you have not turned the AC to the "ON" position, or there is a problem with the temperature setting. "Low" could mean either "Low Temperature" or "Low Fan Speed". Designers of AC systems (not only in cars), often have a problem getting the controls right. Some ACs do not operate if the fan speed is too low.
Have you had your car serviced recently? Sometimes testing procedures/diagnostics leave the AC in the "OFF" position.
First you should check the error code of the Auto Climate Control System:
1. Switch the AAC system ON (thats the auto and ac lights are on).
2. Press and hold the OFF button.
3. Press the face level button 4 times within 2 seconds (timer start is when you push the OFF button).
4. All the LEDs will illuminate and every segment of the LCD will show.
5. A number will be shown in the LCD.
No Fault = 00
He said it was a bad condenser...
1 - 10 of 10 Posts
