2014 Sorento EX AWD V6
Hi all
When I come to a slow speed stop in normal driving conditions, my abs is pulsing. I took it in to dealer, they said they fixed it by putting in new sensors, next day it did same thing. Any thoughts?
Sorento SX AWD 2015
Take it back. They looked at it and clearly didn't fix the actual cause.
Yep, take it back. Brakes are the most important item in a vehicle! Best not to fool around. When they 'repair' it again insist on the svc manager going on a test ride with you prior to your sign off on the repair.
2017 Sorento SXL
it's not the sensor. your problem is one of the front wheel hub assemblies. it is starting to develop some play, thus triggering the ABS sensor at very, very low speeds when you apply the brake.
If you want to stop this from happening until you get it fixed, just pull the ABS fuses. ABS light will come on but you won't have this happen.
Sorento 2015 LX 2.4 AWD, Suzuki 2011 SX4 AWD, ( 2000 KIA Sportage, junked)
YES, just pull the 7.5 A ABS3 fuse on the left., above HORN and BLOWER
www.avigex.ca/kia/fuse0s.JPG
THe main 40A fuses are part of the integrated fuse block and pulling this block would also disable a lot of necessary items. Notice that pulling the 7.5A fuse also inhibits ESP and TC gimmicks, and AWD. RUnning in FWD is not a problem....most cars do.
