2014 Sorento LX
So the abs and traction control light has come on. First thing to do? It’s stopping just fine.
First thing to do is get it somewhere that can scan the vehicle that has CAN/BUS capability(BCM/ABS/SRS and higher level than just OBD11). Codes are very specific to fault.
In the meantime you could get out your owners book and locate the fuse panel and see if a fuse for ABS system has blown. Light on while driving means the ABS and Traction control systems are not functioning...just normal power brakes.
  • Like
Reactions: Lou O.
Sorento 2015 LX 2.4 AWD, Suzuki 2011 SX4 AWD, ( 2000 KIA Sportage, junked)
Do as Ron has asked for.
YOu probably have a wheel speed sensor shot...possibly with a shot wheel bearing. Loss of wheel speed sensor does inhibit ABS and AWD .
AN advanced code reader can tell which wheel is the culprit. Most common code readers do not read wheel / brake/ transmission codes. .
2014 Sorento SXL V6 3.3GDI FWD from USA
There is a TBS for ABS Sensors on FWD Sorentos from 2011 to 2015, at 74k miles change mine first right, then left in about 2 weeks diference, the go bad.
