What's the best way to remove the trim between the windscreen and front door of a 2010 pro_cee'd?
I need to fit a dab radio aerial and the ground needs to be in contact with the body metalwork for the amp to work.
Is it just a question of prising it off with a bojo, if so where do I start and are there any gotchas?
Is there any danger of disturbing the curtain airbags?
RIP :( 2010 Pro_Cee'd - Infra Red 2
I take it just any old earth position won't do, it must be up high?
Sadly I can't offer any assistance, but have you used our Search function?
If anyone comes across this wondering how to get this piece off it's pretty easy. There is a screw hidden behind the SRS badge. Just pop that badge off with a trim tool, remove the screen and then the trim can be popped off held in place with two clips one in the middle and one towards the bottom.
There is a cable behind this trim which I'm guessing has something to do with the airbag. I removed the negative terminal from the battery before I started just in case.
Thanks for letting us know fuzzthe!
I'm sure that'll be useful to somebody, and I'm glad you solved your aerial issue in the end.
