I'd like to take advantage of the expertise on this forum and pose a wheel/tire question regarding my "other" car, the 2004 MB C230 Sport Sedan. This car has staggered fitment tires & wheels; 17x8 on front with 225/45 and 17x9 on rear with 245/40. The staggered fitment makes it impossible to do a four-wheel rotation and the super-wide rears wear out fast due to the excessive scrubbing action on turns. The 2004 C230 Sport Coupe has identical wheelbase and front & rear tracks. It had identical wheels and tires at all four corners; 17x8 with 225/45s. So, I'm thinking there's no reason to stick with the staggered fitment. One plan is to go with 215/45(XL)s all around as they will fit on 8" rims. This would require different (ie, 17x8) rear wheels. I'd actually prefer to go with 205/50(XL)s as they are a slightly better OD match. In either case the smaller XL tires very, very nearly match the load specs of the OEM tires. Another option would be to go with 225/45s all around.
What do you guys think of this plan? BTW, the only reason I'm considering all this bother is that the car is in great shape with <50K miles and should be good for many more years. Thanks!
