I did a drain and fill on the transmission as preventative maintenance. Used Valvoline Maxlife ATF. $18/gallon at Walmart. About 4-5 quarts came out, and it was dark! Fair amount of metal shavings on the magnetic drain bolt too. Decided to drive around and do another drain and fill. Pictured is 1st fluid change (left), 2nd fluid change (middle), and new fluid (right).
This is what I did.
STEP 1: confirm transmission temp is about 140 F
STEP2: remove filler plug (22mm)
STEP 3: remove drain bolt(24mm), let ATF drain out
STEP 4: replace drain bolt (35 ft/lbs)
STEP 5: remove level plug (3/8 drive)
STEP 6: pour new ATF into filler hole until a small steady stream comes out of level hole
STEP 7: replace level plug
STEP 8: pour into fill hole 700 ml of ATF
STEP 9: start car, let trans warm to 140 F, then cycle between Park and Drive with 3 seconds between each, and about 3 times.
STEP 10: Engine still running, remove level plug, if a thin stream flows out, level is correct. If nothing comes out, add more ATF until a thin stream comes out.
STEP 11: Replace Level plug and filler plug. FINISHED
This is what I did.
