1 - 8 of 8 Posts
2013 Kia Soul
Hi, my passenger side seems to be getting wet when I drive in a storm. I think I have at least a couple of holes in the underside.
Could someone please tell me if that's what it looks like to you, or does it look more like something important is leaking?
I was thinking if they are "just" holes, I might be able to use some Gorilla Waterproof Patch & Seal to fill them up?
2013 Kia Soul
looks like some... drain hole?
Thank you for taking the time to reply Cochise! Yes, there are definitely some intended holes in that area. But the part where I think I'm having a problem are those white areas where it looks like it might be torn away/rotted from the frame.
I'm wondering if those white areas are just insulation or something with nothing above them but the interior of my car. My hope is that I can just patch those up and be good to go -- versus them being some kind of tank that contains fluids or something.
Best to take it to a body shop and ask them.
Perhaps they can stuff some type of caulk or filler material in the non factory holes.....
  • Like
Reactions: LoganSoul
2013 Kia Soul
Looks like my problem was a busted AC drainage line leaking into the cabin, not the holes!
Most times it's either AC or rain-related.
It's a big area that's retaining moisture. If the problem doesn't get fixed, I wouldn't seal the spot. I would do the opposite and drill a few holes for better drain. That will lessen the large wet spot.
  • Like
2013 Kia Soul
Discussion Starter · #7 ·
Thanks for the advice. I had a car with a leaking trunk where I did that!
I'm getting it fixed, but waiting on delivery of what seems to be the most custom tube ever made.
Moderator
99 Kia Elan 1.8L
Looks like you soon get that a-hole out of your soul.
1 - 8 of 8 Posts
