A week ago I replaced the A/C compressor drive belt. It ran perfect for 2 days or so but then started squealing. I adjusted the tension and the tensioner is in good working order, but it still squeals a little. Sincerely its driving me crazy and I know it isn't the alt or the PS drive belt. Any suggestions??
2006 Kia Rio 1.4 16v dohc
To prevent squeals i usually clean the pulleys with soap to remove dirt (grease, oil, dust, etc) and, after the installation of new belt i spray on it silicon grease (only a bit). Try to clean all pulleys and new belt with soap and water and after apply some spray grease on the belt in both side (contact with pulleys and over).
Thanks for the reply!
I've done some more observations and it seems that the source of the problem is the compressor. When the A/C is on and the compressor clutch engages, the compressor gets stuck and that's why it squeals... I've tried some WD-40 and it stopped for a bit, but it keeps doing it. I think that the belt has too much tension.
2020 Hyundai Palisades
from what you have described it sounds like a problem with your compressor or compressor clutch and to add a silicon spray to a belt would do nothing but make the belt slip.
Update:
I just finished adjusting the tension in the idler pulley and it went away... It ended up being the belt was to tight.
Discussion Starter #6
Another update:
It went away for a few days, but it started again... Got under the car and found out that one of the tabs where the tension screw sits had broken :/
No A/C again 'till I can get a hold of that bracket
