Have a 99 sportage, had a few issues. Car takes a lot of cranking to get started and I have to massage the gas pedal. Once started it idles fine but once I put it in gear it chokes and stalls out. Any suggestions on this?
Had a few problems before all this. Car overheated and blew main hose. Replaced hose, thermostat(this was the overheating issue), tempature sensor. Prior to that is was running rough. When I opened the spark plug well found oil in there. Cleaned really good and replaced plugs, wires and boots.
Any help on this would be great.
Cerato S Hatch Auto
How bad was the overheating? Check compression of engine. Oil in spark-plug wells means gaskets need replacing.
