1 - 9 of 9 Posts
Does anyone know of a wiring skematic available quickly for the back of the CD Player / AM FM Radio that fits in the 99 Kia Sephia??? There are all these cut wires coming out of this white conection and they're all different colors. I bought a harness that fits my Sephia's connection and has the colored wires that are labeled but I don't know if it will coincide with the colors on the back of the radio. I want to splice the wires together but I'd like need to be sure.
Can anyone help?
Thanks,
Kelvinkia
[email protected]
About CD install, I'm having the same problem. Someone cut off the original Kia conectors and did a hack job of splicing an old Pioneer harness to it. Some wires are not connected at all. I found out when I unwrapped a few feet of electrical tape covering the "splice job". The original Kia colors seem vague to me and I don't know how to verify what wire does what in a questionable situation. I bought the radio back to Wal-Mart and they refunded my money! It's a job vfor a pro I think. speedster1
I ended up buying a sony gt2000 it has a aux out in front, I bought it from best buy. I will try to figure out the wiring my self but if I couldnt figure it out I will take it to the best buy they have offered free install.
Hi Everyone,
My Factory radio went blank (some kind of power surger, I think. - anyway,
I'm going to install a used Pioneer I have - Bought a wiring Harness BUT !!!
HOW DID YOU GUYS GET THE DASH OFF and THE OLD FACTORY RADIO OUT ????
BTW - Wiring Harness shows the following color code;
These go into the Kia 'mating plug' - EIA Wiring color code -
The plug has Male pins, that are not numbered or marked.
1. 12V ignition/ Acc = RED
2. 12V Bat/Mem = Yellow MALE KIA Plug
3. Ground = Black
4. Power Ant. = Blue Facing you with center 'open latch' on top
5. Amp turn on = Blur/White
6. Illumination = Orange | -------------------| |------------|
7. Dimmer = Orange/White | |
8. Right Front+ = Gray | 8 10 12 14 B B B 5 2 1 |
9. Right Front- = Gray/Black | 9 11 13 15 B N B B 6 3 |
10. Left Front+ = White | |
11. Left Front- = White/Black |--------------------------------------------|
12. Right Rear+ = Violet
13. Right Rear- = Violet/Black NOTE B = Blank no wire or male pin.
14. Left Rear+ = Green N = Not even a hole for a pin.
15. Left Rear- = Green/Black ALSO this KIA wiring harness DOES NOT
have a #4 Blue = Power Antenna
or a #7 Orange/White = Dimmer.
Hope this helps someone, Now all I have to do is Get the OLD radio OUT.
Thanks,
Garry
2000 Kia Sephia
Ok when I bought my car It had a clarion head unit in it.
I know how to get the dash off in a 2000 kia.
Unscrew the two screws above the guage cluster, then procese to pop the dash off. Disconnect the clock, the rear defroster, and the emergency light wires,. Be sure to take the top of the streering column off. Tilt the dash and the radio will be right there.
Heres a link if you get confused, lol sorry im half alseep its hard to type.
http://www.carstereohelp.com/stereoremovalKiaSephia.htm
:57:
Originally posted by moinm@Oct 22 2005, 01:59 PM
Hello I am a newbie, I am trying to find out info about different wires that are comming out of the player. Specially the 8pin connector wire that looks like an s-video type cable. can some one help me?
does your stero support a cd changer? i think that might be what it is
something like this may hook up to it
http://www.crutchfield.com/S-5FwRCzEVefD/c...50&I=500KCM122B
i want to integrate my ipod by using an aux input adaptor...have you found out anything more?
i think this may work
http://www.crutchfield.com/S-m3ToiqWn5dY/c...us&i=469ALPMRCA
i bought one from them and i'm gonna try to install it when it comes in
i remember seeing some instructions on how to get the dash out of an '01 sephia...anyone have the link
i'll let you all know if it works
1 - 9 of 9 Posts
