98 Sportage hard starting, transmission hunts
1 reading
2K views 3 replies 3 participants last post by  ylr
#1 ·
My 98 Sportage automatic 4X4 is very hard to start; I have to go against common wisdom and floor the gas pedal before it sputters to a start. It also hunts gears seemingly randomly while going down the road, going from overdrive to 3rd and back in a matter of seconds. A trip to Autozone for a diagnostic revealed no codes, they recommended taking it to a dealer.
Ideas? Thanks!
#2 ·
The requirement for a full throttle start is an indication that the engine is in flood mode, flooring the pedal cuts fuel..
The transmission will never run properly until you rectify the engine issue...
Code scanning is not enough, use a live Data Scanner and see what the ECU is not happy with..
... Philip
