1 - 1 of 1 Posts
98 Kia Sephia 1.8
Hello,
This is my first post, I have learned alot just lerking around and now have a issue I can not solve.
98 Sephia 1.8L
The engine turns over but will not start/run.
I have checked...
Timing: The DOHC marks on both cams line up correctly and the mark on the crank is ok also.
I checked for codes and there was none
There is Fire at the plugs
I have attached a fuel pressure tester and it reads 50+ psi when you crank the engine. (it has fuel in the tank)
tested all cylinders and have good compression on each ( within a few pounds each)
1 - 1 of 1 Posts
