97 1.8 5spd Sephia
Hi,
On my 97 Kia Sephia I have a 455 code
I was wondering if this, which nobody can tell me what it is is pointed the right way.
There is an arrow on it that I highlighted in red.
Is the part pointed the right way?
Thanks
1996 Kia Sephia GS
Sorry to reply so late. Mine is installed in the same direction as yours.
Evaporative Emission Control System Leak Detected (Gross Leak)
1
Check evaporative hoses between fuel tank, fuel tank pressure snesor, evaporative emissions canister and canister drain cut valve. Are hoses OK?
Yes
Go to next step.
No
Repair or replace as necessary.
2
Check for proper installation of fuel tank components. Is installation condition OK?
Yes
Go to next step.
No
3
Erase diagnostic trouble code from memory. (unplug battery a few minutes)
Is same code number present after* rechecking?
Yes
Replace PCM.
No
Intermittent poor connection of harness or connector (Repair connector and/or harness).
Thats what the kiatechinfo.com site says to do. If you want to use the site (its awesome) use internet explorer it goes slow and stops working in most other browsers.
