Hello, all. I am having trouble installing a power steering-A/C belt on my 96 Sephia RS 1.8L.
There is a tension adjustment on the power steering unit that I have made as loose as possible, but I can not get the belt (I'm pretty sure it is the right belt) to fit over all the pulleys. Any suggestions?
Thank you!
hi! you have to loosen two mount bolts the hardest to find is behind the p/s pulley you access this bolt thru the oval holes in pully,just keep clicking the ignition key till the hole comes arround . the other is just below the tensioner screw hope this helps
Thanks, metalpapa. I have done this and still can't get the belt around the 3 pulleys. The p/s pump moves, but it doesn't seem to move very far.
