Hi, the horn died just when inspection is about due. When I press the horn button on the steering, I can hear the relay clicking. I am guessing that means the actual horn is jammed or dead.
I looked everywhere under the hood but can't seem to locate the horn. Anyone got a working horn location? Thanks...
- DC.
I am not sure if the 95 is the same as my 99. If it is it is mounted right behind the grill in the front between the two headlights. There are a couple of clips and 1 or 2 screws holding that in, I believe. Once you get that removed you should have direct access to the horn, if our years are the same that is.
Good Luck
~Vince
