1 - 1 of 1 Posts
KIA OPTIMA DVD GPS Navigation player with 6.2 Inch Digital HD touchscreen & PIP RDS Bluetooth
Your Price:US$ 330.00
Model: QL-NIS711
Order Now:Kia Optima DVD Player,Kia Optima DVD GPS,KIA OPTIMA navigation system with digital touchscreen bluetooth
Compatible with Nissan Tiida & Versa 07 08 09 & 2007 Note & 2009 Cube & 2007 Micra & Cefiro & Paladin & Livina Geniss & Qashqai & Livina & Sylphy & x-Trail.ha (it may not fit all versions and all years, so please pay attention to the size of this DVD palyer and your original radio.)
6.2" Digital High Definition TFT LCD touch screen
With 800*480 high pixel resolutions, full HD screen brings you superior picture quality over the normal standard player. You'll see details and colors like never before. And it is quick and easy to enter to your required menu with flick of your finger.
Built-in GPS navigation
Built-in GPS capable of 16 GB SD card provides excellent high-quality visual guidance. You can also get turn-by-turn destinations and prompt voice guidance to avoid getting lost or delaying. And millions of POIs help you to quickly find the closest restaurant, gas station, hospital and so on.
iPod® and iPhone® Joyful
iPod and iPhone users rejoice. This player is compatible with iPod and iPhone. An additional specific cable is included, which enable you to connect your iPod / iPhone and enjoy quality audio streaming via the original car stereo system.
Built-in Bluetooth® Hands-free
Wirelessly connect your Bluetooth capable cell phone to the player to listen to calls or A2DP music streaming through your car’s audio system. You can dial the phone number directly from the keypad on the player screen.
Radio® RDS-enabled
Catch up to the current news via the AM/FM/ RDS-enabled radio system. You can use automatic / manual channel search and preset up to 24 your favorite stations.
With RDS, the radio can display detail program information and transmit frequency data for the same station. When you are making long trips, this function allows the radio to automatically switch to the particular frequency with the best reception for the particular network of stations that you want to listen to.
TV ® DVB-T Supported
Easy access to a video wonderland through the built-in analog TV, and limitless live broadcasts are right here waiting for you even on the go. You can choose to have built-in DVB-T, which allows you to receive stronger and clearer digital signal in the car.
PIP
You can use 2 functions of DVD / TV / Radio / Bluetooth / Navi / AUX and run two windows at the same time. Zoom in and out them at your will.
2-Zone
Independent source can be played simultaneously on the unit. For example, the AM/FM tuner can be listened to by the front passenger, while the DVD video is available to the rear passenger. Need to add an external monitor, and we recommend Universal Headrest Monitors.
Steering Wheeling control
You can adjust the volume, forward / backward music directly via the steering wheel control. Therefore you can intently focus straight ahead, which will make the driving safer.
Auto Rear Viewing Function
Parking and reversing will be very easy and safe with this rear viewing system. Because the clear picture of rear side will be automatically displayed on the full screen while reversing.
The rear view camera is not included, which you need to buy in additional. And we recommend Nissan Cameras.
USB / SD card slot
It features 2 mini SD slots on the front panel (one for GPS map, one for music and other files) and 1 USB slot on the back. It supports flash drive and SD card, maximum 16GB*3, which give more ways for your favorite music and photo files move.
Virtual 6 disks CDC
6 audio discs can be stored in the unit while you are listening to music. It gives you the benefit of extended playing time and direct selection from any of the six discs. And you can enjoy hours of uninterrupted audio listening.
Make it your own player
Customize the player as per your preference
Select your button light color: Red / Blue / Purple / No.
Select your touch sound and switch mode
Select your starting wallpaper
Select your EQ effect
Seamless Installation
Original factory panel design and wire harness, so you do not need to cut any wire of your car. Setting it up is simple and you don't need to worry about messy wires. It is a Plug-and-go player.
1 - 1 of 1 Posts
