1 - 14 of 14 Posts
2013 Sorento Ex V6
This is after 11 refills so far, 90% in city. Don't know if the mid dip was winter grade, now summer seems to be better?
Warmer weather will do it. I'm not sure if they've switched away from winter gas yet, but back in the fall when I first put it in, it killed my gas mileage.
My gas mileage has been improving lately (Michigan). My daily commute was taking 5/8 of a tank, now I'm only using just over 1/2 tank over the same route. Hopefully it will continue improving as it gets warmer! Warmer air is also better for fuel efficiency.
White 2012 SX AWD
Did you have winter tires on and switched to summer tires?
I believe those can reduce mileage also.
Switched mine a little while ago...had no choice. A screw very near the sidewall of one tire with, luckily, a very very slow leak.
I bought my winter tires at Kal Tire. Had them switched over to summers. They guarantee tires...not labour,though. Paid $40 for a new replacement. They threw in free summer storage for the winters. I don't normally do that but took them up on it. Saved me a few trips back and forth. I'm not affliated with them but I would give them my recommendation on the above average service and competitive prices...especially the service. FYI, they provide seasonal tire change-over for free if you buy tires from them.
Sorry to go off topic :)
I always ride on all-seasons. Even in the brutal Michigan winters. I did have them siped, though.
White 2012 SX AWD
Doh! Missed that.
Meebers, I guess you don't have to worry about gas variations by season, either.
2011 Sorento AWD V6 SX Cherry Black
If 90% of your mileage is in the city, I would say that you are doing quite well. You should be able to get within the 27+mpg range on long trips. Spring and fall, when you don't have to use the A/C, will probably bring even better long trip mileage. One of the few vehicles that can beat EPA highway ratings if you try.:D
2013 Sorento Ex V6
Discussion Starter · #13 ·
I am looking forward to a several hundred mile trip in it. I have seem posts here that 55mph seems to be the sweet spot? As I am driving in the city, I keep monitoring the AVG mileage indicator and notice if I am careful I can make it increase by a tenth or so. Once in a while I mash it and can see it go down.:eek:
12 RIO 5 SX, 07 VW Passat 2.0L turbo 1952 Siata Diana
Just a warning. Summer tires must not be used in cold climates. Tire Rack has that warning on every summer tire. Look at the tire adds in Road & Track, or any other car magazine. Summer tire rubber compound hardens in the cold, and the thread pattern is designed for warm climates. They are epically dangerous in snow or ice.
1 - 14 of 14 Posts
