does the 2wd system have enough power to go through light off roading?
I iy0ga · Registered Joined Mar 24, 2005 · 7 Posts Discussion Starter • #1 • Mar 26, 2005 does the 2wd system have enough power to go through light off roading?
I Ilan · Registered Joined Aug 29, 2004 · 153 Posts #2 • Mar 26, 2005 Of course you can go off road with a 2wd Sorento, just keep it light. You can enjoy the ground clearance. Don’t try sand you will get stuck.
I iy0ga · Registered Joined Mar 24, 2005 · 7 Posts Discussion Starter • #3 • Mar 26, 2005 well ill be in az...so its all sand...and i just want to go beach riding. i just cant justify spending 22-25k for the 4wd kia.
S Spec SX · Registered car Joined Dec 24, 2004 · 4,208 Posts #4 • Mar 26, 2005 You will get stuck in the sand with a 2wd. I have been out in sand once with my Sorento. I started off in 2wd and then got stuck. Had to throw it in 4wd to get out.
I iy0ga · Registered Joined Mar 24, 2005 · 7 Posts Discussion Starter • #5 • Mar 26, 2005 wat was the conditions?
S Spec SX · Registered car Joined Dec 24, 2004 · 4,208 Posts #6 • Mar 26, 2005 The sand was very dry. It wasnt packed at all it was very loose. I was going up and down hills.
