Here's some tips I found for my 2026 Sportage Hybrid EX:
1. Chill Self Driving / Auto Pilot with Comma.ai (Comma 3x), amazing to say the least!
2. The 2026 Kia Sportage (except for the PHEV) features a dual-level cargo floor that allows you to adjust the height of the cargo area for increased flexibility. The cargo floor can be set in a higher or lower position, depending on your storage needs. I use higher (which is about 5 inches higher), so I can hide all my hiking gear stuff and tools, and leave the cargo space empty!
To use the dual-level system, you simply lift the cargo floor panel and reposition it into one of the two available settings. High position: When the floor is in the higher position, it creates a flat loading surface, which is useful when the rear seats are folded down. It also provides a hidden storage compartment underneath for valuable items. Low position: The lower position provides several extra inches of vertical space, allowing you to fit taller or bulkier items.
3. Need a Dash Cam? This fits like an OEM behind the center mirror cover, WITHOUT any needs for cabling or power! Look for FITCAMX. Super convenient!
4. Faraday Bag for the key fob. If you don't have DigitalKey2, but can still open or close the door via Kia Connect, this is helpful for whenever you don't want to carry your car key/fob, or if you want to leave your car in a parking lot for family or friends to pickup later, when you are not around. Put it inside of the bag (which blocks the FOB signal) hide it inside of the car. When you or the person arrives where your car is at, just open the door via the phone, get the key out of the bag, and you (or they) are good to go!
5. Center Consoles Organizers (see pictures, real must haves!) I can provide links if needed.
