I thought I read that this Kia can recharge from the running engine. I've also read that this lag sounds disruptive or unsafe; how bad is it?
I thought I read that this Kia can recharge from the running engine. I've also read that this lag sounds disruptive or unsafe; how bad is it?I can't imagine it can be durned off. Regen is the ONLY way for a hybrid to recharge the battery pack.
You are correct. I corrected the comment. If you eliminate regen, that means the engine is the only source for charging. Doing that would make the HEV a real gas hog, as the engine now has all of the heavy lifting for recharging the battery pack.I thought I read that this Kia can recharge from the running engine. I've also read that this lag sounds disruptive or unsafe; how bad is it?
I have a PHEV coming in this month so I don't have any experience with this yet and I understand that turning off regen on the PHEV isn't as big of deal as pure HEV. I'm thinking when the PHEV is running HEV how big of deal this would be. I'm worried about yields, roundabouts, etc.The lag can be pretty stunning when it happens, especially if you really need to get moving to avoid an accident. Stomp the pedal, but it has to think about what to do for a couple seconds before it responds.
In my experience, this only happens when the vehicle is almost at a stop. In most cases it isn't an issue if you are going through the yield or roundabout at 10-20 mph (a more typical speed) anyway... it only happens when you actually need to yield to another vehicle and slow down to less than ~3 mph and then accelerate again without a complete stop. It will also happen to anyone at a stop sign that doesn't actually come to a complete stop.I'm thinking when the PHEV is running HEV how big of deal this would be. I'm worried about yields, roundabouts, etc.
Sometimes it just takes some break in miles to get everthing to smooth out. We as drivers also have to get use to how much pressure to put to the peddle . I have the 2.5 Tucson ( same engine and transmission) and after 4000 miles it smoothed out. Hang in there!Hey everyone!
Received my 2023 Sportage Hybrid SX-Prestige on June 19. Had to put an order in about a month earlier so didn’t take too long to arrive. Also got it at MSRP which was nice. Swapped my 2019 Honda Insight for it.
Anyway, just seeing if anyone else has had the issue of an almost lag, or pause of the shifting/transmission when pulling away from a stop?
It happens randomly and usually only like once a drive, usually in the beginning.
Scenario:
I leave my house in electric, the engine kicks on at some point…I have a stop sign not far from where I park so I’ll come to it, slow down…and if I don’t come to a complete stop and try to press the gas then after breaking…it feel like it doesn’t know what to do….the electric motor nor the gas engine engages for like a second or two before it is like…OH YEAH I’m supposed to be going! And it almost lurches a bit to make up the delay since…by this point…I’m pressing harder on the gas to actually move!
again, it only happens at those moments of almost stopping but not really but I’m concerned it will do it while trying to merge on a highway or something. Seems very dangerous.
I have an appointment this week to have the emissions done and to fix a squeak with a handle so I’m going to inquire and have them drive it. Could be a software update or something.
Just coming from my Honda and it’s CVT, the electric motor would always engage to get the car going and it never did anything like that. But maybe I’m just not used to driving a car with gears anymore…hah.
Anyway, thanks for any insight anyone!
Besides that, car is awesome. Looks cool. So much tech. Comfortable. Etc etc.
Thanks!
NO. The hybrid and PHEV have completely different engines and transmissions - 1.6T and 6-speed auto. Mine is at 8,700 miles and still does it just the same as the first time I noticed it.Sometimes it just takes some break in miles to get everthing to smooth out. We as drivers also have to get use to how much pressure to put to the peddle . I have the 2.5 Tucson ( same engine and transmission) and after 4000 miles it smoothed out. Hang in there!
I have the same issue with my hev ex 2023, not sure what to do about it.Hey everyone!
Scenario:
Thanks!
Come to a full stop at stop signs.I have the same issue with my hev ex 2023, not sure what to do about it.
It's not always about stop signs. There are many yields that could spark this issue. That's where I encounter it most times.Come to a full stop at stop signs.We have never had an issue with our hybrid.
That was a joke.It's not always about stop signs. There are many yields that could spark this issue. That's where I encounter it most times.
UPDATE: You were correct, @Koreanadian. I showed my wife the auto hold feature about 3 days ago in the drive through line. I did not know it would stay "on" until I pushed the button again. It rolled into the garage today after we stopped so smoothly and effortlessly.Is it a transmission issue or auto hold?
I think its purpose is more for stop-and-go driving, like having to stop at lights every other block. Allows you to take your foot off the brake and rest your leg. Not much use for it here though, where we have only one stoplight in the whole town.That's so weird ... on the ICE, I had an issue with using Auto Hold because it would prevent the vehicle from moving after stopping at a light or something. Never understood the feature on it anyway since it's not a manual transmission and will rarely stop at a steep incline where it would slide backwards
