I have a '22 Soul purchased new in Dallas, Texas in March of this year. The car currently has less than 10k miles on it.
Twice now in the past 2 months, the dashboard screen that sits between the Tachometer and Speedometer has changed the language from English to Danish after starting the car.
I assume it's Danish by what Google translate says.
The language on the radio can be changed to four different languages: English, French, Spanish, and Korean. These settings do not affect the dashboard.
When the setting changes to Danish, I can go down until I see "Nulstil" (reset in Danish) and attempt to reset it by selecting "Ja" ("yes" in Danish) to reset all the dashboard settings. However, this does not reset the language. According the the car's owner manual, page 61, "All menus in the user settings mode are reset to factory settings, except language and service interval." There are no other settings listed that indicate the language can be changed. I assume its a hidden menu or something programmed from the factory.
The last time this happened a month ago, I turned off the car, went into gas station to buy a soda, and it switched back to English when I restarted the car. I did not put any gasoline in the car that day. Today when it happened it did not automatically reset itself after restarting the car a few minutes later. I even took it to the nearest Kia dealership to see if they had any clue on how to fix it, and before I knew it I had several tech's yelling at each other "You gotta check this out!" and they poured over it for 20 minutes trying to figure it out as they had never seen it before. Several resets and restarting the ignition did nothing. Unfortunately, it was closing time, but they did suggest disconnecting the battery, which would be the simplest solution given that it reset itself last time.
This language change occurs immediately after starting the car without me changing any dashboard settings or pressing any buttons during startup. The only setting I changed prior to stopping at the gas station today when it happened was the dashboard brightness since the sun was low and I couldn't read it. Immediately after filling the tank the language changed. Please note these same events did not occur when it happened last month as I did not put gas in the vehicle both times. I initially thought it could be a bug with it resetting the fuel gauge, but that does not appear to be the case.
I got home and left the car off for 2 hours...by then it finally reset on its own. Has anyone seen this before? I tried a forum search and could not find anything. I've tried searching elsewhere but all I get are discussions and videos about the radio's language setting, not the dashboard. Are there any fixes or is there a hidden menu I do not know about?
Pics below.
When it happened a month ago...
After 10 minutes and restarting the car...
Today...note the change in mileage...
Pics below.
