2020 Sportage LX 2.7L V6 AWD
current sw version qlpe.usa.sop.v103.181206.dau_a
Currently do not have navigation. No SD slot. I tried to dl the an update from Kia. I get the Insert media device , message.
Is there any way to update?
Also , Is there a resource for the Engineering mode settings? Some settings can be changed but not clear as to what they are.
TIA
THe problem is in getting the correct update and getting it installed. THe Firmware will not recognize the files on the USB
2019 Kia Sportage EX
in the Navigation Updater software provided by kia, instead of selecting the model of your kia you use the search field and type the beginning of your SW. I think is qlpe. and then you will have your update file. It is also important that the usb stick must have 32GB, no more and no less than that.
