1 - 7 of 7 Posts
2019 Sedona..can't see how to run fan without AC running. When turn knob to run fan , AC light comes on and pushing AC light button does not turn AC light off. Thanks.
Make sure your not in defrost mode.
A/C will run to assist in defrost mode.
eg.
USA
'15 Kia Sedona SX
I don't know your model, but pp. 4-146 through 4-188 of the Owners' Manual deals with HVAC.
Assuming your HVAC is automatic, pp. 4-184 onward ("Defogging Logic") may be useful.
And, to make Lou O.'s post stronger
Make sure your not in defrost mode. A/C will run to assist in defrost mode.
In defrost mode, A/C cannot be turned off (it's a humidity thang).
2019 Kia Sedona LX
Is your temp knob on "Max AC"? If it is then turn it up on notch and you should be able to turn off the AC using the button.
Sent from my Pixel 3 using Tapatalk
eg.
USA
2007 Kia Sedona (2 of them)
A remote possibility, but if the prior posts did not solve your problem -- a blown fuse.
I blew a fuse on a 2007 Sedona, the one that managed part of the air controls. The car went into "safe mode" for the HVAC, which included a strong fan, AC, and air sent to the defrost vents. I could not change it until I found and replaced the blown fuse. Scared the crap out of me frankly. The car seemed to be in full rebellion mode!
Best guess is that you had some other part of the controller set to defrost, and the AC is turned on "as a courtesy" which drives me nuts on modern cars. If you give me a button for the AC, do what I tell it to do.
1 - 7 of 7 Posts
