1 - 15 of 15 Posts
2018 Kia Sorento LX AWD V6
Hi, new owner of a 2018 Sorento. It has the factory roof rails. I was looking at some aftermarket crossbars for the roof, but I notice there are two sets of holes pre-drilled on the inside of both roof rails. Are these for factory crossbars..? THX :)
THX - I see I can get generic crossbars online that will attach to the side rails for not much for than $50, and the factory crossbars are $250? Is there a big difference? Sure a lot of price difference..
2018 Sorento Limited
I don’t know, but if you have a sunroof make sure they’re compatible. I kind of regret buying the factory cross bars as opposed to spending more for more versatile Yakima or Thule. There’s a limited selection of accessories for the factory bars.
I have no sunroof. I will do some more research. I don't have immediate plans to carry anything, but DON'T like the fact that you can't "tie off" things to these new kind of roof rails that have no space under them which to run rope, etc. like my 2005 Ford Escape had. Is this done for aerodynamics? Why would they NOT have a small gap under them which you can tie off to..?
Totally agree. Bad design decision. I tried to find something I could clamp on to the factory bars to use for tying things down (separate thread somewhere), but didn’t find anything I liked. Haven’t looked recently though.
Discussion Starter #7
Bumpin this - is there any reason I whould opt for the expensive OEM crossbars versus sthe aftermarket ones available on EBAY or AMAZON..?
Discussion Starter #10
Mine is non-sunroof, I believe the sunroof requires special one? Anyways, I hope we can get some info soon, or I will just go ahead and buy an aftermarket one..
2018 Sportage EX
The only differences between OEM and non-OEM roof rack crossbars are appearance and crossbar profile. The appearance is subjective but the rail profile impacts the attachments that you can install on the roof. Some have a square profile, some are round and some have a streamlined oval type profile. They all have roughly the same capacity so there is no benefit of going OEM.
Discussion Starter #12
THX - There are two threaded holes each side on the inside of each rail. Are these used to bolt the crossbars?
2018 Sportage EX
I think the holes are meant to secure the OEM crossbars in place. Many aftermarket bars simply clamp onto the rails on top of your car. This is what I have (my Sportage rails are similar to the Sorento's). They stay on very well, are adjustable and very easy to put on and take off.
Discussion Starter #14
Maybe that is why the OEM cost more, they are designed to bolt on? As long as the bars stay secure...
The holes are not threaded. They are there to locate (or maybe to limit the location of) the factory crossbars, which are definitely not easy to remove and reinstall.
1 - 15 of 15 Posts
