A closer shot of the connector in question
I may have used the same piece of paper towel to wipe it off. But wasn't oily originally.Is that cover to right oily? It look like from the pic.
Forgot to mention, I'm in Ontario. No Autozone's up here.I would stop at a local auto parts store like Autozone that scans the car for free just to see what codes are stored.
The box to the left of the connector is the engine air filter. In your first picture you can see a couple of small hoses from the engine to the 90-degree elbow. If you're getting significant blow-by you could be getting oil on the air filter which then leaks to the connector. Check the air filter.
BTW, that's an interesting diagnosis - let us know if it turns out to be correct, with oil migrating along the wiring harness from a leaking oil pressure switch.Hi Karl,
I checked the air filter previously, it's clean. My oil level is good, but my oil pressure light has been flickering, which makes me think the oil pressure sensor is bad. I'm picking up a replacement tomorrow. I've read where oil can wick up through the harness to the ECU connector. Possibly my issue.
Max
Have not. I would not expect a problem there as harness was always lifted straight off. Is this a known problem? Can the ECU be disassembled and cleaned?Have you confirmed the proper pin tension, loose connections will cause intermittent faults.
