1 - 14 of 14 Posts
· Registered
2017 Kia Sorento 2.4L LX
I have a 2017 Kia Sorento 2.4 lx. I'd like to know whether if it has a MAF sensor or a MAP sensor and it's location (picture if possible) so I can first try to clean it before replacing it.
The issue I had was infrequent. I started the car and it started shaking, I pressed the gas all the way in and it wouldn't respond, then it turned off. When I started the car again, everything was back to normal.
· Administrator
Most of the later models will have an MAP.
Post a photo of your engine and we'll confirm.
The MAP seldom requires cleaning and best left untouched unless you have verified indication that its not performing correctly.
· Registered
Better to leave the MAP seldom alone then. When I scan the car, it shows no trouble codes. I wonder if the issue is related to the spark plugs. The car has around 115k miles.
· Administrator
Not sure how you can expect an answer to that question when you haven't yet described the issue/symptoms.
· Registered
It's in my first post. The issue I had was infrequent. I started the car and it started shaking, I pressed the gas all the way in and it wouldn't respond, then it turned off. When I started the car again, everything was back to normal.
· Administrator
Best get a reputable service shop or Kia dealership to inspect and test the servos for the variable intake manifold in addition to other systems.
  • Like
Reactions: maguireCR
· Registered
2015 Sorento SX 3.3L V6 FWD
How's your oil condition, thinking maybe variable camshaft stuck. The CVVT failure codes (DTC's) sometimes take 60 seconds of failure to set. R U turning engine off rapidly after running rough, or giving it some time to clear? Just wild guessing at this point. In any case post #2 s/b the way to go...
· Registered
Discussion Starter · #10 ·
Hi bobdec, thanks for your input. I recently bought the car and immediately replaced the oil, oil filter and air filter. I put 5w-20 full synthetic oil (Castrol). Next time it happens I will give it some time in order for the computer to catch the DTC. The engine running rough has only happened twice. The first time it happened, my wife turned it off immediately and the second time, i pressed the gas pedal expecting it would respond but it just stopped running.
· Registered
2018 Sorento EX 3.3L V6 AWD
You take a look at camshaft position sensor or crankshaft position sensor? Pull out, clean then reinstall? Sometimes there can be an issue before a code is thrown. But that happened to me on a 2012 base model.
· Registered
MAP is normally located on or around throttle body and should be easy to remove. You can pull it out and spray clean it with carb cleaner, shake cleaner off and let it dry then reinstall and check how engine starts and runs.
I had hard start and shaking issue (sometimes wouldn't even start) with Forte and MAP cleaning fixed it right away.
· Registered
Sorento LX V6 2018
Does your code reader show pending codes as well? How about freeze frame data? It's really hard to diagnose prior to a code unless it's pending or can be shown in freeze frames. The complexity of intake systems puts several culprits in the way - Crankshaft Position Sensor, Throttle Position Sensor (only it's not a TPS any longer, it's in the pedal assembly since it's an electronic throttle), MAP, variable valve timing and intake. I believe that any of those can create a pending code before they actually light up the CEL. Intermittent problems are the worse unless data is captured when it happens and you actually have something to show the shop.
· Administrator
Correct, a diagnostic approach is always preferred and most often the less costly, but based on mdesjard's question whether his car uses an MAF or MAP it's my guess that he does not have the experience to do the type of diagnostics that you have suggested.
Another thing, we don't know the mileage and service history - poor oil change intervals leads to issues with the VVT.
1 - 14 of 14 Posts
