1 - 11 of 11 Posts
2016 Sorento SX
Haven't been able to find any other threads about this issue...
Since getting my Sorento I've had an issue with a gap between the headlights and highbeams. After being reassured for months by the dealer that it is normal and them releveling the lights in various ways to try to satisfy me, they finally acknowledged it wasn't right and replaced the headlight assemblies under warranty, however it didn't fix the issue. I've attached a pic that hopefully shows what I mean.
Does anyone recognize this issue or have any suggestions? Every time I mention it to the service reps they are just scratching their heads and don't seem to have any clue. And they aren't open late enough to test drive in the dark and see just how frustrating it is as it creates a horizontal blind spot. Thanks for any ideas!
2016 Sorento SXL
I think I read the main and high beams are linked together but they can be separated if you remove the linkage. You might want to explore this in more detail its possible your linkage has been altered or not in sink with the low beams
2016 Sorento SX
it is normal
Well I'm embarrassed to have made such a big deal about it if that's the case, I just can't understand it. Does this not bother you? In the city I don't notice it but I am driving on back roads daily so this really affects me.
If I have the headlights at what I'd consider a normal level then there's a huge black strip in my line of sight between headlight/highbeams. If I adjust them down to where high beams seem normal then the headlights give me about 25ft visual (like in the pic) and I feel blind without the high beams on. If I adjust the headlights up so I don't need high beams then I can see better but then people are flashing me all the time.
My wife refuses to drive it at night because of it.
2016 Sorento SX
A
Appreciate your suggestion. I would have thought that replacing the headlights would fix this but this at least gives me something to bring back to the service desk. Don't think I'd be comfortable messing with it myself.
Sorento SX FWD 2015
My 2015 SX has 3 adjustments.. A- High Beam Vertical, C-Low Bean Vertical and B- Low Beam Horizontal. Strange both sides are out. Top pic is Basic Headlight, Bottom is HID.
2016 Sorento SX
Discussion Starter #7
Thanks for your response. My understanding is that on the 2016 there is only vertical and horizontal adjustment and both high/low beams move together.
Sorento SX FWD 2015
Yep 2016 was a re-design, so many year and model small differences it's hard to keep tract, I did not know about headlight adjustments changing. Interesting that they expect every bulb, headlight assembly and chassis to be perfect, I wonder if they shim something during assembly that is not a field recommended process. Your picture looks like your left high beam is too high, right not as bad.
PS: If it's bad enough you could pay a reputable body shop to look into it, and get an estimate. They are used to straightening out lighting alignment after some pretty bad front end repairs. Hopefully yours should be a quick job for them. Worst case would be a new headlamp assembly.
2019 Sorento EX V6
If you replace the high beams with good LED's you will have less of an issue. The LED's have a little more diffusion and will give a more pleasing view.
2016 Sorento SX
Discussion Starter #10
Thank for that great suggestion, I'll see if I can find somewhere to look at that.
2016 Sorento SX
Discussion Starter #11
Interesting idea, thanks for that, I'll check into it with the dealership.
1 - 11 of 11 Posts
