1 - 9 of 9 Posts
2016 Kia Picanto 1.2ex
Hey guys
Im new here. Has anyone ever added cruise control to these models? And is it just a matter of buying the steering controls and installing them?
Anyone that has done it, what is the process?
Thanks in advance everyone
Sent from my SM-N950F using Tapatalk
2013 Kia Rio Sedan Auto 1.6 Turbo
Hey guys
if its throttle by wire should just be plug and play.
I also think so, but I was just hoping that someone else here has done it before that could confirm for me. Would be great.
In the US we don't have a "Picante" or "Cee'd" but we have a "Rio". And I put CC on my base model Rio (1.6 GDI) simply by adding buttons. If you want I can take pictures of the Steering wheel and the plugs on the clock spring. I'm pretty sure the Picante is just a Rio and the Cee'd is like a Rio/Forte. Even though you have a different steering wheel and motor, most of the body parts are the same. (not 100% sure tho)
We can cross reference clock spring part numbers if you know what yours is to verify. And you can cross reference ECU part numbers from a CC model of the 1.2L to ensure they have the same ECU and Clock Spring.
Discussion Starter #6
The Picanto is also known as the "Morning". Its a 3cylinder 1.2litre... see attached picture. We also get the rio, not the same though. I will also add pictures of interior and steering wheel
Discussion Starter #7
Ok so what should I look for and where?
Discussion Starter #9
The previous post pictures are actually the ones WITH cc...
1 - 9 of 9 Posts
